Now that my other Sears tractors are coming to a close I decided to start a new project. Since I got into the hobby I had always wanted to try a restoration, and have the extra time now gave me a good start on it. This project is a lot of firsts for me, and once I get back to work progress will be slow (maybe even Ellis project slow :hide:.... his reason is for quality tho, mine it is hard to say). It will be a rattle can restoration and a lot of details of it are going to change as we go, so it should be fun
. It will not be a fully authentic resto but will have some modifications
The tractor itself is a '75 ST/16 that I purchased in a lot of attachments. It was a mostly complete tractor less an engine which had been taken apart and left in the rain. I have people give me engines quite often so once I get towards the end of the project I will decide on the engine. The 1st and 3rd picture is how I got the machine. The rear rims, weights and hitch got taken for other machines, my spare rusted set of rims were put on, and the front tires were replaced with the take offs from my Dad's Kubota as a spare set of rims having 16.5x6.5x8 6ply tires on it
I didn't take a lot of pictures of disassembly but have it pretty well broken down. The PO liked replacing parts with overkill, the large pulley was for the idler, and once tearing down the front end he had used an upgraded tie rod too. I will be replacing those items back to stock
The nose cone was bolted back together with a steel plate. All of the pieces are there, it is in 3 seperate pieces, so I have been watching videos online on how to fiber glass and plan to try my hand at it. I purchased a DIY kit made my Bondo and plan to try it in the next few days. It probably will be far from perfect, but I don't think I can make it worse :sidelaugh:. It's a nice little project to learn on! If anyone has any nose cone repair tips or fiber glass tips in general I'm all ears!
The transmission was the major part the tractor project hinged on. After pulling the shifter it looks good inside so the project is on. One bolt broke in the rear anchor point so we have been working to remove it. The PO had this rear end out at one point in its life, the shifter was freshly greased, shifter gasket was torn inside before I opened it, brake band bolts were lose, and washers were missing from the rear frame section
Sent from my SM-A520W using Tapatalk
