1 - 11 of 11 Posts
I might be buying a new welder but I don't know much about this one and can't find much info on it. Let me know if you know anything about it or find something.
"It is a Dayton 250 amp Mig, Tig and Stick welder it is made by Grainger model 3z564 "
Also do you know about how much I should buy it for? I don't want to low ball her but I also want a good deal.
Thanks is advance
When I went to Grainger this is what came up for that number. Doesn't say anything about it being a Mig??? Does say that it is Discontinued!
DAYTON Welder, AC/DC
AC/DC Welder, Input Current 76 Amps, Open Circuit Voltage 78 Volts, Welding AC Current Range 30-250 Amps, Welding DC Current Range 30-250 Amps, Rated Output Current @ 20% Duty Cycle Current 250 Amps, Rated Output Current @ 100% Duty Cycle Voltage 30 Amps, AC/DC Dayton, Uses Electrodes Up to 1/4 Inches All Position
Grainger Item #3Z564 Price (ea.) N/A
BrandDAYTON Mfr. Model #3Z564 Ship Qty. 1 Sell Qty. (Will-Call) 1 Ship Weight (lbs.)142.0 Usually Ships** Discontinued Catalog Page No. N/A Country of Origin
(Country of Origin is subject to change.)USA
life is good
Yup same thing here. That is just a stick/arc welder.
I know tig welders can also have arc capability.
Any dc stick welder is a tig welder.
To get mig and stick out of same machine,you need one that is constant current[stick,tig],and also constant voltage[mig,flux core],,
Thats all the info I got on it too.
Thats what confused me. I have a mig and I have a stick 2 different machines. I also heard of tig and stick welders together but not all three in one. (at least not with out spending several thousand $$'s)
Yeah,your average buzz box won't,,that one in the picture won't mig,,but you can tig with it I'm betting.Lead for stinger needs to be hooked to straight polarity,hook that to a tig torch,,than your argon. Bam![or pop]
Dan
You say dc welder can do tig welder?
My miller big20 doesn't say about tig welder. it say DC welder with 200 amp 100% duty cycle.
life is good
Yeah 2 late that would be a fair price if it works good.
Discussion Starter · #10 ·
I offered her $50.00 ( I feel like I'm low balling her) I asked her if she got a chance to see about how much it was worth and this is what she said.
"Actually I didn't but make an offer... I am truly not sure of the value but it needs to go.. "
Yep,I said any dc stick welder can do tig,,yours included,,,you need a tig torch rig,with copper connection block,argon hose, regulator and flow meter[probably something I'm forgetting],you need to make your stinger dcen,,than hook up every thing,,,
1 - 11 of 11 Posts
