1 - 12 of 12 Posts
What # Mid-Mount grader blade will fit my 1979 C-101?
Thanx,
Ron
P.S. and I am hunting one complete, around these parts in Missouri an eastern Kansas at a fair price.
I'm almost willing to bet any blade will work. I built this mid grader for my 64 704. And wouldn't you know it it goes right on my 76 C-160 as well with NO changes!!
Thanx,
Ron
40"
1979 model 97-40BM01 Replaces MB-405, 7-1111, 7-1112, 7-1113, 7-1114, 67-40BM01, 77-40BM01, 87-40BM01,
Replaced by 07-40BM01
Followed by the 50"
07-50BM01, 07-50BM02, 07-50BM03, 79351
You can likely view the ipl's here
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Garry
I sold my welder an all awhile back when I got sick...:dunno:
My point mostly was the attaching and lift points are almost identical thru the years meaning any WH blade should bolt right up:thThumbsU:thThumbsU
40"
Followed by the 50"
Garry
Adding
A 79356 blade for the 5xi-Series will also fit if you move the rear 3/4" crossbar ahead 5". It is welded in so I cut it off and added a new one locked in with set screws leaving the side frames as they are. The bar ends could be drilled out of the frame if it ever needs to go on a 5xi again.
These 50" blades mount to the rear axle quick hitch like the dozer blades.
Garry
Discussion Starter · #9 ·
I think I'll keep Looking for a 40"er Garry. I am in the can't do much anymore shape, so I hafta have something I can just put on an off fairly easy.
Thank Ya anyway kind Sir
Ron B.
Discussion Starter · #10 ·
Changed my mind, after talking to 2 different people. One wouldn't even bother telling me if it was a 40 or 50 inch an didn't want to walk out an look. The second never even offered to send pics of a like new one he has.
I really don't care about one after these deals. I just wanted one for looks anyway.
I never have run into or dealt with any rude people on the JD forum, not here, (I have both) its a complete different bunch over there. IMO
1 - 12 of 12 Posts
