1 - 7 of 7 Posts
Didn't like the ball valve solution, so I made something easier.
A couple fittings, a few hoses, and a valve block, now I can select which to lift on the fly. Only have 1 leak, the cylinder lower O-ring, because I didn't put a new one in when I just had it out. Oh well.
Now I can lift the box blade, drop the plow and backup without having to mess around. A handle facing upwards is on the list, but for the time being I'm still flexible enough to reach this one.
If you install the power beyond port in your TVC you don't need the valve shown in the pictures.
Shawnmc749 what valve did you get and where from? I would like to do this to mine.
I got it from princess auto, 8orb inputs and outputs. 8orb->1/4" JICM fittings to the cylinders and replumbed then to 1/4" JICM and new hoses. For the TCV you will need a 5orb->1/4" JICM fittings to eliminate the tee's if you have 2 cylinders already.
Thanks for the TCV, and the coin, haha. I bought a Kubota 4x4 diesel for $2000, so building that to last instead.
Also scored a running driving 644 with 3 pt hitch, case ballast box, belly mower, rototiller and about 50% of the 648 backhoe. Missing the crowd arm, control valve, hoses and cylinders, and got all of for $1500 20 minutes away!! Figures, the day after I got the Kubota. Oh well.
I have a Kubota diesel use it for mowing only. I run a 60" deck, bought it new . Get ready Kubota are some of the highest priced tractor parts
1 - 7 of 7 Posts
