1 - 1 of 1 Posts
This oldy is new to me. It came without a carb. If anybody may know, If I put a carb on it from a 10 hp Kohler, which has the correct linkage and mount, will it lean out and hurt it or just less powerful than the correct carb ? Also if you please, does anyone know what exactly goes into the hydrostatic trans/diff/fluid pump? I believe it is all one unit as far as the fluid goes. I have read about ATF type F, Regular hydraulic fluid and dextron II but am not sure. The unit has a filter and I would like to put in fresh fluid and a filter before I test start it. More questions to come. Thanks for any help you may offer.
1 - 1 of 1 Posts
