1 - 2 of 2 Posts
I need help removing the filter inside of the air cleaner oil bath. I remove the canister which holds the oil but I cannot seem to remove the filter. Is this suppose to slide right out of the bottom or is there a trick to taking it out? Thanks for all of your help.
It doesn't come out it is spot welded in there, remove the canister and soak in diesel for awhile them blow out with airhose
1 - 2 of 2 Posts
