1 - 1 of 1 Posts
MF202-FEL and BH "Mater"
Hello everyone,
I am working on my MF 202. One of the projects is the installation of a 17 GPM front pump and along with it a 25 GPM suction filter. All existing mounting is being replaced with the pump mounting moving from the loader frame to the axle support to eliminate the angular shaft movements when using the loader.
I am looking for an ideal mounting location for the filter. The fluid reservoir output is located at the bottom of the side frame. The centerline for the pump is about 9" higher.
At what point if any do I need to be concerned with the height location of the filter assembly and elevation head?
Thanks!
Don
1 - 1 of 1 Posts
