No way to give a value without more info & pics. IF she runs good with no smoke & pulls fine, then the tractor alone is worth a solid $1,000 minimum.
Does she have 3pt lift? Rear PTO there? The decks have composite toothed timed pulleys. These are nearly impossible to find, so better pull the cover & look at the pulleys. The teeth should have a flat top to them. If worn to a sharp point, then they are worn out & deck won't last long to mow with unless you can somehow find some or have machine shop manufacture them (pricey).
The blower I have no idea as to worth. Not many blowers in my parts, so no education on them. It should at least be worth $250 in working condition.
So if all in good working order, has 3pt & rear PTO, my opinion is somewhere around $1500 to $1800. Quite a bargain compared to what you get these days for that money. If in superb condition it is worth much more.
