1 - 3 of 3 Posts
Giday all,
My MF-14 is not charging I guess it has not been charging since I got her.
So, I have 28-30volts AC coming out of the Engine so I think that is not the problem.
When I connect the Volt meter to the B+ coming out of the voltage regulator, Red to B+, Black to Ground I get -5volts DC. I have changed the voltage regulator with another probably 30 odd years old as well and still no difference, any thoughts??
I am thinking both the voltage regulators are faulty is there any other way to test them?
Thanks for that link. Handy to have.
I was going to suggest you download the Kohler service manual
from MTF reference library. I walks you through some tests.
A good manual to have on hand.
Good to hear to solved the issue.
1 - 3 of 3 Posts
