1 - 2 of 2 Posts
Hi there, just bought a mf135 and I need help please. The tractor I bought was from a dairy parlour so not had best of life.
Looking at taking pick up hitch assembly off to put drawbar on in time, the four bolts holding assembly on are they threaded in to casting? Rusty and seized would heat be the best way of removal? Any tips to help?
Other problem is differential pedal is also seized could that be an internal problem? Any help would be much appreciated as im a complete novice at this if you hadn't guessed
Hi Mcconnel man welcome to MTF ... I would soak it with a good penetrant like WD40, PB Blaster or Kroil...I would spray and bang it a little to vibrate the piece every day for a few days...at least 3 days....then give it a shot with a wrench...if it fails soak it some more....bank it a little bit some more and then blast it with some heat...eventually it will come loose...try this forum Massey Ferguson it is for Masseys specifically and you should get some valuable help there
2442849
1 - 2 of 2 Posts
