Massey Ferguson GC1715 problem
4136 Views 4 Replies 2 Participants Last post by  jakenease
Mine is a 2015. It has 230 hours. Recently it has had a miss. It runs perfectly at any RPM using any implement while sitting still. However when the tractor is moving forward or in reverse it has a miss almost every time at any RPM. My first thoughts were air filter and fuel filter and I replaced both. Anyone have any guess to where to look next?
Fuel injectors.
Mine are out of whack due to a rollover a couple of years back and now need a tune up. I had to replace one of them after the rollover.
I haven’t had a rollover or anything close to it. So most likely they need adjusted? Is that labor intensive? Also out of curiosity how much was it to replace the injector you had changed?
Fuel contamination is the most likely reason.
Agco parts books is the source for part numbers. Sign in as a guest. Jacks small engines is an alternate from using the dealer for parts. I found that the prices were a bit better at Jacks.
There are two parts needed for an injector, and they are sold separately (at least they were when I bought mine). A pair of C-notes are going to get pretty much trashed.
I appreciate it. I have had injector cleaner in this last tank of fuel and the problem has gotten worse. So I guess I am taking it to the dealership. I can change out the injectors myself but currently do not have the tools to test the injectors I pull to see which one is bad. Thanks again.
