I recently bought a MF230 and it appears that it is set up for some kind of power steering. There is a single hydraulic cylinder connected to the left side of the tractor that runs to the front wheels.
The tractor turns somewhat easy when turning in small increments. But when you have to really turn the wheel one way or the other, you really have to crank on the wheel to get it to turn tight. It just doesn't seem like it should be that hard. I don't know if it is because the cylinder isn't moving correctly or even at all.
I took the reservoir cap off tonight to look at the fluid inside. Here is a picture of the inside of the cap. It doesn't seem like it should be that color. The fluid inside almost looked like a weak chocolate milk mix.
Any suggestions on how to get this going would be great.
