1 - 1 of 1 Posts
I'm having a problem with my power steering, I completely drained the system replaced the seals in the steering pump that the steering wheel is attached to. Replaced the lines that were leaking. I did all of this because the system was leaking and the steering wheel would turn but wheels not turning. Tried adding fluid which helped but It still has not turning like it should and became hard to turn. So I decided to fix all the leaks and refill the system. I haven't been able to get any movement.
Any suggestions?
1 - 1 of 1 Posts
