1 - 3 of 3 Posts
hello everyone first post to the forum. just bought my first tractor. my mf 35 1963 turf special is leaking powersteering fluid out of the left side pitman shaft. if i replace the oil seal on the shaft will that stop the leak. issue #2 the pin that holds the shifter from spinning in the gear shift lever seat is broken how is that pin replaced. i see a hole on each side of the cup but the pin sheared off and a piece is still in the hole. if i use a punch will the broken piece fall into the transmission or into the cup. thanks for all your help
check for wear first if there is a bushing gone and the shaft flops around a new seal won't fix it. if the shaft is tight a seal should do the trick just be sure to check the shaft for roughness where the seal rides the shaft may need a sleeve
1 - 3 of 3 Posts
