1 - 6 of 6 Posts
I've used Dexron for the last 30 years in my 1655 with the same Sundstrand that the 14 uses. A Sunstrand bulletin that I have states that most good quality hydraulic fluids are acceptable and I read somewhere many moons ago that as long as the oil meets the Allison C-3 specs, it's fine. The updated Allison spec is C-4.
What colour is your oil? That'll give you a hint on what was on it.
NOT ENOUGH MUD OR SNOW!!!
TUDOR, it's red ATF. I had a fella who worked at the Massey plant here when it was still open tell me only type-F ATF. If you have made DEXRON work for years I may just use it then. Thanks TUDOR.
2503 hours on the clock.
You're welcome.
I use Ultramar Ultratrac, Tractor hydraulic and transmission fluid. It is in abundance around the farm. Works good.
1 - 6 of 6 Posts
