1993 STX 38 all of a sudden a week after my first cut this year is probably a good half quart high. I understand gas is getting into the crankcase. The engine runs fine otherwise.
My deere service manual talks about the needle valve in the carb bowl not seating or a gaslogged float. It never mentions the electric fuel solenoid other than showing it on the parts diagram.
From what I've heard the solenoid tends to be the problem.
Can the solenoid be taken off the carb while on the engine or does the entire carb need to be removed to work on it?
Is the solenoid serviceable?
Does the solenoid work by pushing up on the carb float when the engine is off? It doesn't appear to be part of the gas supply system otherwise.
The tractor has been sitting almost a week and there may be a slight increase of oil, but I don't see the drastic increase of the week before.
I'm just trying to learn a little more about it before I work on it.
Maybe I just had a bit of dirt. I ran some seafoam in the gas on my last cut.
