I've seen the XT1 at the local CC dealer/farm center I frequent for other items, but I'm unfamiliar with its capabilities and build.
If this model does have a sealed unit, don't touch it as for sure it could very well void the warranty, depending on how the warranty is written. It might void the mower as a whole, or just the part that you worked on that wasn't designed to be a maintained item.
If it is sealed, how by dropping the transaxle would you be replacing the fluid? Is there a plug on the top, or go through some cover you've been told about? Is the fluid something you can even get at your local dealer? I'd start there first, because if its' not available and you put in something that the bearings/seals aren't designed for, or a different viscosity than found at a local automotive store, it could spell even bigger problems later on.
OTOH, If it did have a fill/drain plug for doing what you want, that'd be a different story as then the factory would be saying that this unit needs maintenance to do the job over time and has a certain schedule to maintain. Then you could get the proper fluid, or a fluid that's comparable to the factory fluid specs, and do the drain/fill routine, but keeping the receipt and make a log as to the maintenance/date and you'd be covered according to the Magnason-Moss Act.
Del
Del
