Yes, just unplugging it will allow the engine to run with no oil in the tank.
Yes, just unplugging it will allow the engine to run with no oil in the tank.I'd like to get an M-series running and don't want the oil injection just yet. While troubleshooting this thing I don't need it on. What do I need to do to it to bypass the safety switch? Can I just unplug the wire harness to bypass that switch so it will run?
There is a spacer plate with a check valve behind the carb.Does it just dribble the oil in behind the carb on that, or is it actually injected into the crank bearing bosses?
