M problem
934 Views 8 Replies 5 Participants Last post by  LawnBoyAnt
Finishing up the yard with the M when all of the sudden I go to engage the blade and the engine dies. It happens all the time now. I can only keep it running holding the handle half way. Any suggestions would be great.
1 - 9 of 9 Posts
Sounds like you must have an M with a BBC. If so disable the black plastic horseshoe shaped switch that lies on the deck below the carb. It should have a lever run between it and a cable. Go ahead and unplug it and see what happens then.
Neal
Thanks Indy (it does have BBC) I unplugged the clip and it worked fine. What's wrong with it?
Bad switch or wiring would be my guess.
Safety stuff. I've dealt with them before. I don't know why they do that.
Have you washed it recently? When that switch gets wet it funks out for some reason or another I've noticed. See what happens in a day or so after its good and dry (if you've gotten it wet anyway) Sometimes they will work like they used to.
Neal
Neal
Thanks, I did wash the mower on Saturday. What happens if I run it without it?
Anthony
Neal
Anthony
You could get hurt. I have one of those if your interested. You could always put it in a bag of rice to dry it out.
Hurt how? Just curious.
1 - 9 of 9 Posts
