1 - 2 of 2 Posts
After an hour of running my GT2000 it will not start again after shutting it off until it cools down. The starter will turn slow as if it has a dead battery and if I try a second later it will turn over as if there was no problem but still not start.
What should I be looking for?
Jonathan
It could be a spark and or a fuel problem get a spark plug tester and try to start it with in place and if you have spark, then check the fuel system to see if the gas line runs close to the muffler or close to the block and if it does either put some high heat insulating material between the gas line and the heat source, have you tried to start it with the choke on when it is hot if not give it a try sometimes it will put enough draw on the fuel to get it to start.
1 - 2 of 2 Posts
