1 - 8 of 8 Posts
Hello, new to the forum. I’ve been reading through the threads for the past week and have learned a lot!
Anyway, I have a JD LX280 with a 42C deck. At the beginning of the season I decided to try out the JD mulch kit. I haven’t been very satisfied with the results. No matter how dry or how short the cut, I always leave a line of grass behind me. Even when I run over the same area 5 times! The line seems to come from between the two blades as it’s directly in the middle of my path behind me.
I’ve read that some people have had great success with the JD mulch kit. Is there a specific way to align the blades when installing. My local dealer said on the LX280, it didn’t matter, but I can’t help but think that since the line of grass is in the middle, it has something to do with the blade alignment.
I’ve also read that people have had success with the Gator mulching blades. I tried to order a set from Agri Supply but the rep said they had no suitable replacement for my tractor. I gave them the blade part number that I found online (M148613) but I’m unsure if that was what came with the tractor as those blades were finally discarded this year. Can anyone recommend a Gator replacement for an LX280 42C deck?
I’ve read that some have had success using the Gator blades with the mulch plug. I’m hoping to give this a try.
Thanks for any help or suggestions!
Thanks. I better learn how to level the deck. I took the deck off to install the mulch plug / blades and was happy to just get the deck back on. You're probably right that it isn't leveled. I'm pretty handy but new to tractors...
Anyone know the part number for the Gator blades for the LX280 42C deck?
Thanks!
I also found with the JD kit that if you set the deck high it could leave a line. I don't think the blades get a good enough vacuum going when the deck is set 3.5" and higher with the JD mulch kit on certain types of stiff blade grass. I mow mine close and didn't have any problems except for the fact I wasn't very happy with the "mulching" ability. Left some pretty large pieces dusting the top of my lawn. I'll be trying the Gator blades using the side discharge on the new machine when it arrives.
Mercdv, you called it... I cut with the deck at 3.75". I definitely have to get a set of Gators.
Can anyone tell me where to go to find the part number for suitable Gator replacement blades?
Thanks.
From experience w/ the dedicated mulching deck, the higher you go the worse the cut. There is even one line in the manual somewhere (off the top of my head I have no idea where) that says cutting performance is decreased the higher you go.
I agree, I assume its a suction issue. I know when I have my deck at 3" the cut is just unacceptable to me. At 2.75 its passable. At 2.5 I get a nice cut out of her.
Happily most of my yard is shaded at least part of the day, so I'm okay cutting it at this height.
1 - 8 of 8 Posts
