My JD LX188 dies every the the PTO button is pulled. The blades turn just fine, and the clutch itself SEEMS to be OK. Ant suggestions? Thank You
:ditto: Check the seat switch and the brake switch.Safety switch for the PTO is bad. Roger
Can you start the tractor without pressing the brake pedal down?Brake switch and seat switch appear to be working properly.
