I was mowing today mower was running great the 1st hour or so then it started acted like it was running out of gas pushed the throtlle up on choke and it ran fine I just filled with gas so its not out of gas shut it off put a new fuel filter on and started filter filled up good but still wont run unless its on choke took carb bowl off and it was clean , took air cleaner out not real dirty so I started it with it out same gotta be choked to run and it runs good on choke like it should when its off so it is a carb problem even poured a little seafoam in while running no changebut what the bowl was to clean no dirt or anything in it any suggestions gonna pull it off soon as I get the chance and blow some air thru it and see if that helps Jd dont show a kit for this its all by piece its a 14 hp Kaw FD420V
