Hey everyone.
I bought a used LT155, ran once and then afterwards, when you turn the ignition, the solenoid would hum.
I checked the voltage.
The battery is getting 12 volts, the line from the battery to the solenoid is getting 12 volts but the line from the solenoid to the starter is only getting 8 volts.
Its a 4 pole solenoid so it has a purple line going out and a black ground going out as well.
Does anyone know if this is a ground issue or what it might be?
All posts and terminals are cleaned and tested except for the black ground because i dont know how to test that.
Any help would be appreciated.
