1 - 11 of 11 Posts
I’m looking for any info on the expected longevity of an LT155 K51 transmission. Anybody have any failures to report? I bought my LT155 4 years ago with low hours (I think – it has no hourmeter!). I think it’s a 2001 model and my best guess from the previous owner is that it only had about 100 hours or so on it when I bought it. I’ve probably put about 200 hours on it. My yard is flat, but the original owner had a hilly yard he used it on for one season. My yard is also small (0.5 acre) and with my fence and trees, I do a lot of 3 point-plus turns. I’m trying to figure out if based on this usage 300 or so hours is a lot or not so much. I figure I could sell it for almost what I have into it now, but if I can reasonably expect a lot more years out of it, it makes sense to hold on to it. Though it shows no outward issues, I just don't know if I can expect a lot more years of service or not - any info is appreciated.
Well I'm not running a LT155 or 166 But I am running a 14 year old Sabre 1542HS with a sealed K51 other than a Little Hydro creep the Trans Is doing Just Fine:thThumbsU
That's good news - thanks for the quick response. Do you have any idea of the hours? How would you rate its life as far as hills and start/stop frequency?
GO TIGERS!
My Scotts 1642 lasted 10 years mowing a steep incline with a bagger. Last year it would start out fine but could not finish the 2 hour process when attempting to pull the full bagger and me up the hill.
This past year I replaced the main drive pulley and changed to synthetic fluid and it is holding its own. I no longer use it as my main mower but it carries me and the bagger just fine on a flat lawn at my Mothers house.
I usually begin mowing in March and mow through December or 40+/- weeks at 2 hours per mowing, 80 hours per year, 10 years, 800 hours of mowing. I have used the mower for other things so I'm going to guess that I had 1,000 hours on it then it began to weaken.
Hope this helps.
You should change the oil in the tranny and then quit worrying about it.
The transmission is non-serviceable. I've seen where people have reported removing them and changing the oil, but John Deere does not recommend it. They simply recommend replacement when they fail.
Discussion Starter #8
Hope this helps.
That's very helpful. If 1,000 hours is not out of the ordinary, mine should have a lot of life left.
Well Most of It Life the Sabre was Used By My Late Grandfather to Cut 1/4 acre Lot twice a week spring thru Summer from 1999 till 2010. It Never Pulled More than a spreader, Sweeper, Spike aerator & De-Thatcher. I have Mowed my 2.5 acre yard with It When My Other tractors are set Up for Garden work in our 3 acre Garden So for the First 11 Year a Hour a week May to October. So say 25 to 30Hrs a year it first 11 years. The K51 Is Probably one of the Best sealed Trans Tuff-Torq made for Deere’s applications Based On collected statistics by Deere.
The K51 has Had Less reported Problems than the K46 as a Model But Keep In Mind the K46 has 43 different Variants and Only 6 different variants of the K51. The K51 was Used Mostly By Deere & Simplicity:thThumbsU
GO TIGERS!
I agree, I have no remorse for the purchase of my 2001 Scotts. I don't recall what I paid for it but it does a great job mowing. The engine is as strong as day I got it (I think), there is not a speck of rust anywhere on it, only the seat shows a little wear. It rides and handles very well and I feel that it has been a great value. I serviced it annually and kept it indoors.
I also had a 2006 Toro GT. It was 25 hp, had a high and low range and 50" deck. Both me and my son would rather ride the Scotts. I sold my Toro with 140 hours on it when I purchased the X729.
Discussion Starter #11
Thanks for all the good information. I'm not worried about the longevity of the engine or anything else really, but I was worried about the non-serviceable transmission. It sounds like it should last longer than I am likely to ask it to.
1 - 11 of 11 Posts
