First post, long time problem.
I've had an LT133 (38" deck) for about 6 years now. I am the 2nd owner.
When I first got it, I went over as much as I could. Changed oil, filters, belts, greased, cleaned and leveled deck, new battery, etc. Not that it was in bad shape at all, just getting it to the point where I knew where it stood.
Ever since I started with it, I have always had a problem with it leaving a thin stripe of grass, just inside the right front tire. It's probably an inch wide but very noticeable. I've looked at the deck and I can't figure anything out as to why it's happening. It doesn't appear that there is anything right along that line that knocks the grass down so it doesn't get cut or anything like that.
I had the BM21817 mulching kit with blades on it last year and that really didn't change it at all.
I'll admit that due to lack of time, I don't clean under the deck, and mow when the grass is longer than it should be and sometimes wet which all exaggerate the problem. Even when i'm not taking much off, I still get the stripe. I'm always mowing at 3.25" on the dial.
The stock blades, JD mulch blades, and my current Gator Blades all leave the stripe. Side discharge or mulch, same thing.
Any thoughts? Just some weird aerodynamic anomaly?
I just want it gone. I get more frustrated as time goes on. Any other LT133 owners experiencing this?
