I've got an old mower I inherited from my dad and he got it from my brother who have both passed away now. It's just kind of sentimental to me to still be out here mowing with it so I kind of put an extra effort in to keeping it running.
Now it's not.
Last time I used it last year, it wouldn't turn off. I was already December so I put it in reverse and killed it. Figured I'd figure it out this spring, I was sure it was the ignition switch. It's not.
Battery is good. It was still charged when I started on it this spring.
Symptoms, turn the key and it won't crank the starter. Nothing. Put the battery on charger, it checks good. Turn the key nothing. Not even a click. Put battery on jumpers from something running, nothing.
Pulled the switch and took to JD dealer to replace and had them check it while I was there and they said it was good, huh? Suggester the fuel solenoid so I bought one. I can't even find the fuel solinoid on this tractor. I don't think it still has that. I found diagrams and there's no fuel solenoin on the carb and no wires going to anything remotely like that.
I turned the key on and jumped across the heavy wires on the starting solenoid and it starts and runs.
Turn the key switch off and it keeps running.
With trans in nuetral, foot on the brake, and engage the mower deck, it dies.
It's like it THINKS it's in revearse and the safety kills it when I engage the mower.
The seat switch has been wired around years ago.
I started it again, running in nuetral, I pull the wire connection from the reverses safety and jumped the wires, it died. I'm thinking that indicates that safety is working or at least not interfering.
I pulled the safety switch on on the brake/clutch and checked with a multi meter. Normal position two poles show continuity, two do not. Pushing the button on the switch and they trade. The opposite set show continuity and open.
This is giving me fits and if I'm to get my money back on that high dollar, $70 fuel solenoid, I better take it back soon.
Any suggestions appreciated, thanks.
Now it's not.
