:Welcome1:
from the way you word your post i take it you are not real familiar with internal combustion engines. if the rod is "loose" and knocking then major repairs are required and you are taking the chance each time you crank it that it will come thru the block. you may already need to bore it out, replace the crank, or even just junk the engine.
