:MTF_wel2: , firefighter4u!!
The drive belt is a possibility, but it's more likely the hydro. The fact that it only slows a little is encouraging. Those little hydros only put out about 2.75 hp to the rear wheels, so hills will have an effect on speed, as will mowing grass heavy enough to slow the engine.
At 300 hours, it's due for an oil change. There is a procedure for changing the oil in a Tuff Torq K46 hydro that starts with removing the hydro from the tractor. They weren't designed for oil changes but they can be done with enough patience. There are threads about doing just that if you do a search.
