I will show my stupidity yet again and ask What is balancing the drives ?
That is
not a stupid question!!!!!
You have 2 independant drive axles. To operate effectively, they should have their drive controls tied together in such a way that they each turn at the same speed as the other throughout their drive ranges, in both directions and when turning.
Think heavily loaded truck locked in 4wd on concrete making a sharp turn. The same issues apply, just not to the same extent. You won't break the transfer case, you haven't got one, but you will wear your tires at a greater rate, they might wear out in 15 or 20 years instead of 40 years. The real issue will be one axle pulling or pushing the other, instead of working together. On slippery surfaces, this can and will be a concern.
Your machine will have widely varying traction capabilities on each axle depending on what payload the bucket has and what surfaces it runs on, eg. the rear wheels on asphalt and the front wheels on snow covered grass when pushing back a snow bank. Fortunately, hydros will soak up all of these discrepancies,
provided they turn at the same rate in an unloaded state. The hydraulic pressures within each hydro will vary according to the work being done, but the swash plates must be set at the same angle (or a close poximity thereof) so that the tires turn at the same rpm. A digital tach will be a real help with this.
http://cgi.ebay.com/ebaymotors/Digi...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Procedure
- Set up the tractor on blocks and remove all the wheels.
- Bolt a bar to the hubs on the opposite side of your drive control together to keep them from turning.
- Remove the return spring from the drive control so that you can 'set it and forget it' while you check the speeds of the other 2 hubs.
- Set up the digital tach per instructions.
- Start the engine and set at full throttle. * SEE NOTE BELOW
- set hydro contol at full forward and check both hubs with the tach.
- Do the same check at mid hydro speed and low hydro speed and the same 3 points in reverse.
- Throttle back the engine to half speed (working speed) and redo all 6 checks to confirm consistancy between the axles.
*NOTE If you haven't run-in the transmissions, now is the time to do so per the manufacturers instructions. For the run -in, you may not want the wheels off.
For roughing in the set-up, low throttle and full forward will get you in the ball park. The above is to verify the final set-up.
Personally, I would want the differences between axles as close to zero as I could get. One revolution of a tire is over 5' of travel. With the bar out of the picture, the RPM drops to half indicated, but that's still over 2.5' of travel. A small amount of slippage may be tolerable.
For the engine size, the only advantage an engine larger than 18 HP can give is more weight. The hydros can only deal with about 7.5 HP each under ideal traction/weight conditions under full throttle and at full speed forward. You
may be able to max out one hydro at low speed, but not both, and neither will be drawing 7.5 HP. Your tractor isn't heavy enough, and I seriously doubt that you can max out even one at full throttle, short of tying the
tires to a tree.
Hope this helps.
