////////////////////////////You could also just back the truck up near that embankment in your photo and load it from there.
Did you put boards down? My last utility trailer had plywood. And the one I bought last year has boards. So my only experience with mesh is on the tailgate of my current trailer. What's better about removing the mesh? I can certainly see boards/plywood being better for hauling mulch, dirt, etc, of course. But if you were moving equipment, I wonder if the mesh might be kinda nice, for grip.Did mesh removal years ago on my 5x10, totally worth it!
Almost as slippery as wood with wet mold/algae growing on it.You don't want to use any type of metal for decking. Its slippery when its wet.
Yup, that's very common with the low-grade mesh the trailer manufacturer uses. My 5x8 has failed in several places. One of my next projects is to remove the mesh and use wood planks or decking. The ramp is wrecked so I removed it. I bought 3,000lb aluminum ramps to replace it. I actually welded on a hand winch today for it. Should make it easier to pull a snowmobile on.I was loading the Zero turn today and the mesh failed in the back corner. I guess I'll either put 2 treated boards on each side over the mesh or take the mesh off and floor it all
with boards.
Cannon
But the mesh, depending on the orientation, should give pretty good traction due to all the edges, I would think? With the "lines" of the mesh going left/right, I would imagine that would do OK for forward/back traction. No?You don't want to use any type of metal for decking. Its slippery when its wet.
I like the idea of re-attaching the mesh, and putting angle iron under it. I've debated doing that on the mesh tailgate of my trailer, but it already has lengthwise supports that line up almost under the tractor wheels. The wheels are just a little outboard of the supports, but they're very close. So I've held off for now, as it would be somewhat involved to add supports, and hopefully they're not needed.I would go for pounding it back into place, then welding it down, and then perhaps weld/bolt a strip of angle iron underneath it, if that area regularly have more weight over it (like say, a tractor regularly goes over that spot).
When I replaced the wood planks on my 18' trailer, I painted them with a deck paint with bits in it, to provide a rougher surface, as I use it in the winter with snow/ice on it, and it somewhat helps, but also has worn off in a bunch of spots, from tires spinning or the equipment shifting slightly during travel...
/////////////////////////////////////////////I hooked the trailer up View attachment 2481620 View attachment 2481621 and drove one of my old Craftsman mowers onto it. With the Craftsman deck all the way up (which is not very high) the deck cleared about 1/2 inch. It probably helped that the hitch on the truck is to high causing the front of the trailer is higher than the back. That would decrease the angle of the ramp. I may get a hitch that drops a few inches just to get it closer to level.
Cannon
I cut the mesh out and ground the welded spots down, then installed treated deck boards. No issues with grip. It was a cleaner install to me than keeping the mesh in place.Did you put boards down? My last utility trailer had plywood. And the one I bought last year has boards. So my only experience with mesh is on the tailgate of my current trailer. What's better about removing the mesh? I can certainly see boards/plywood being better for hauling mulch, dirt, etc, of course. But if you were moving equipment, I wonder if the mesh might be kinda nice, for grip.
Yup. Even for my ramps, which are mostly mesh, around the edges and down the middle (it's a split ramp) is flat steel, and there is zero traction on that part in the winter, I need to make sure to both keep the equipment wheels and my feet off it.From what I've seen people moving equipment in pouring down rain and snow they slip and slide all over the place loading and unloading with a metal floor. If you get mud or ice on the deck its even worst.
