1 - 20 of 31 Posts
Sweet-good job !
How did you size the belts?
2 stroke addict
and where did you buy the belt? and what size is it? prob last longer than the orig snapper oem
Napa Auto.
George, I took the old one with me. the new one is 3/8" by 25", the old one was like 25 1/2", but Napa doesn't sell 1/2" sizes.
Napa Auto.
Bet they'd have the smaller transbelt as well? Mine seems to struggle on the hills. I think a complete belt change and adjustment of the drive wheel is in order.
2 stroke addict
they should, i didn't replace mine though. i will get you the part number on the drive belt in a little bit.
5K Poster!!!
Could you please explain what you did here? Did you change a tranny or something? I see a new main drive belt but no explanation to what you did to make it an extra speed....
Thx.
2 stroke addict
Discussion Starter · #9 ·
huh? my mower was not SP, and I changed it over to 6 Speed SP. i did not go from 5 to 6 speeds.
before the swap
Thx.
I had an extra 6 speed deck complete with a dead briggs. Nick swapped his WR engine onto the dead briggs SP deck. Nice job.
Oh btw-Nick which SP pulley did you use the briggs one?
2 stroke addict
Discussion Starter · #11 ·
actually, the Briggs isn't dead, it has no spark though. going to put another coil on and see if it will run.
and also, i did not use your deck, I swapped all the SP parts over to my deck.
yes, I used the Briggs pulley.
the belt is a 3L250W.
Ah-I see nice way to do it. Well I guess what I meant by dead briggs is no spark so "in a coma" briggs might be better stated.
The part number is for the main drive belt correct? Mine is rather stretched so I am going to pick one of these up-and size up the small trans belt also.
Thanks
5K Poster!!!
Ohhh I see. Thx...was confused there.
ya made it work out,
good job
napa isnt going to have the trans belt. its a special type belt. my napa dosnt sell the 25 inch belt you used either -26 is the shortest they list in their inventory. however a woman waited on me...... try tighting the trans belt adjustment spring if it slips. there is lots of adjustment on the spring
Thanks Dan...I'll try that !
2 stroke addict
Discussion Starter · #20 ·
you sure? i think my dads truck uses a similar type belt to drive the alternator and stuff, i am sure you could get it in a shorter size.
1 - 20 of 31 Posts
