Re: looking to make a sleeve hiych for a 220
Here you go.
Here you go.
The sleeve hitch will work for any sleeve hitch attachment.Does anyone have pictures of one of these? I'm used to seeing a complete 3pt set-up. I'm very interested in this option for hooking up a rototiller, would this also work for a drag blade?
-Learning new stuff every minute i'm logged on here, lol. Thanks
Thats a nice design you have there.:thThumbsUHere is one I made after seeing one on a Sears mower and before i did much research on the Case. Built it with trial and error but works good with my Brinly single bottom plow.
You would also need for the slot to be extended 4 inches, which would weaken it for down pressure on the 400 series.So if one was to make one to fit a 446, it would also fit on a 220 but it would simply stick out 4 inches farther? (21 1/2 compared to 17 1/2 for a 200 series)
The schematic shows three holes for implement attachment; most have one like Buckeyebuck's. Is for some lateral adjustment of a plough, or do some implements use more than one hole.
Thanx
Is this in reference to the holes in the Diagonal plate that attaches to the rocker shaft arm?The schematic shows three holes for implement attachment; most have one like Buckeyebuck's. Is for some lateral adjustment of a plough, or do some implements use more than one hole.
Thanx
Thanx
Thats what I was trying to say!The other 2 holes are for mounting the implement off-center
