After 6 decades and over a hundred blade changes, you'd think I'd learned my lesson on assembling a mower deck.
As a public service, here is what I just encountered here on a rainy day, dedicated to sharpen the blades on the Cub Ultima ZT2 60" deck.
They were beat up but managed to get a nice new edge on them. Cleaned up some minor stuck clumps under the deck and went to install the blades.
One refused to mesh with the star on the spindle...hmmm....😠
Here is the warning:
Don't be in a hurry installing blades. BE SURE THEY ARE FULLY MESHED WITH THE SPINDLE STAR if you have a star or other cut out type of mounting arrangement. If you don't mesh them, and tighten down the blade, it WILL SPIN the blade on top of those star points and mushroom them down, and will mushroom the cut out in the blade as well, never to go back together again.
Using a Dremel I salvaged just enough star points on the spindle. Using a small file, I managed to salvage just barely enough star cut outs on the blade. It was very tight but the nut pulled it all the way in. This may last a few more cuttings, but not more and certainly will not go back together again.
Now, here I am, $127.67 poorer than 2 hours ago, because I was too hasty last time to confirm the blade was fully meshed on the star spindle mount before torqueing it down. I've done this job maybe a hundred times and still this time, screwed it up royally. Hope this will cause you to double check that on your next blade install and save yourself the cost of a spindle.
Beware of haste!😩
Beware of haste!😩
