1 - 9 of 9 Posts
I am restoring an original Zenith carburetor for a 1930 International Harvester truck (see photos); the venturi is unfortunately missing. Said venturi must measure 1-3/16" O.D. (appx. 30mm) in diameter and 1-1/2" long (appx. 38mm) in length. The restriction size is unknown, but I doubt it matters that much in this case since the truck will be used primarily for old vehicle and implement shows. I have already tried a Model A Ford's Zenith venturi and it is a tad too small ind diameter and a quite a bit too long.
I got the bright idea that I just might be able to use a venturi from the "ag world" since the carb is so small, but I don't know where to begin looking for one since I must search by size rather than application. I am not opposed to doing a bit of machining to make one fit correctly if it is already "close", but it is beyond my capability to scratch-make one from a plug of metal stock. Does anybody have any suggestions or leads?
Jeff
2443824
2443825
Everything I'm seeing online has the flanges for the bolts perpendicular to the orientation on the one you pictured.
If all you are needing is the venturii then try this site: 1928-31 Zenith Carburetor Venturi, Single - Grumps-Garage
Thanks; I have plenty of Model A Ford venturis around here and they are a tad too small in diameter and quite a bit too long. The diameter could be shimmed but the extra length is a problem because I would disturb its aerodynamic properties by cutting it off unless I went up in there with a Dremel and tried to re-contour it . . . which is what I may have to do.
Jeff
What you have is an updraft style carb.--- Did you try something like an IH F-20 tractor? --- I am trying to picture a carb that size on tractors and they look close.
Thanks to Sonny and all others for their input. I thought that I had posted here earlier that I found a solution, but apparently not. I found a guy who will turn them out for $15/apiece and I am ordering some from him.
Jeff
1 - 9 of 9 Posts
