Wow! MM forum is like Dead! With summer coming will be looking into buying or Making 3pt on the ZB once again if anything new has come up? Have another problem with tractor. I replaced the front Pedestal cuase old one had a big open crack down it's side. NOW, with tractor setting I see oil leaking down it's side. Appears this new unit Also has the crack, only much finer, hard to see until it got oil in it. Wondering if I will have to remove whole thing again to get proper cleaning to be able to have welded?? Think I can flush out enough if I take off the hub/axle below and run some kerosene or other cleaners down thru it? Is real PIA to remove with rad mounting on it and other items. I can tear down in garage and know a portable welder to come here, just not sure if it can be done without better cleaning? Maybe should just tear down again and blast part too, start fresh. Also thinking maybe a mag-flux should be done to be safe on making sure I have ALL the cracks sealed? That sounds best really.
