That was the sole reason for the long frame to start with. No 60", no worries. But the next thing that you get after getting rid of the long frame will be a 60" deck.
That was the sole reason for the long frame to start with. No 60", no worries. But the next thing that you get after getting rid of the long frame will be a 60" deck.I have a 8129 tractor that is fair to poor shape. It needs a paint job, a steering wheel, tires, battery, deck rebuild, engine rebuild/replace. I am starting to question why I should keep the long frame tractor. Isn't the turning radius larger on the long frame tractors?
I could put a 16hp Briggs on the 8129 and turn it into a 8169. Is there anything about the long frame tractor that makes it more desirable other than the ability to run a 60" deck? I don't have a 60" deck and I don't foresee one showing up at my door anytime soon.
For me the answer is Leverage. Though it is a minor point, there is a difference. Run a 44 inch snow blower on the front of a short frame tractor, then a long frame tractor, then a longer frame 24G... and you will experience the difference in traction and control. This also applies to running the rear tiller. When the weight rack is further out front you will get more leverage. Though I have not tried the rear tiller yet on the 24G.Is there anything about the long frame tractor that makes it more desirable other than the ability to run a 60" deck?
Agree. Little better ride too. Regarding the turning radius, either swap in a Pro-G front axle or grind the stops off the existing axle to match. I saw a big difference in the turning radius when I moved a 16-G axle to my 8179/816 project. Even just rolling it around in the garage was easier.For me the answer is Leverage. Though it is a minor point, there is a difference. Run a 44 inch snow blower on the front of a short frame tractor, then a long frame tractor, then a longer frame 24G... and you will experience the difference in traction and control. This also applies to running the rear tiller. When the weight rack is further out front you will get more leverage. Though I have not tried the rear tiller yet on the 24G.
Leverage is one of the reasons I am set on getting the Kwik-Way front end loader installed on one of my 24G tractors. With the same amount of counter weight on the rear, I can lift more and/or have better traction and control.
All the best,
Tom
What becomes the stop then? Can you get pictures of the front axle at full lock, etc to show the difference. I'm curious about doing this....Agree. Little better ride too. Regarding the turning radius, either swap in a Pro-G front axle or grind the stops off the existing axle to match. I saw a big difference in the turning radius when I moved a 16-G axle to my 8179/816 project. Even just rolling it around in the garage was easier.
18G:What becomes the stop then? Can you get pictures of the front axle at full lock, etc to show the difference. I'm curious about doing this....
Your eye is accurate to atleast 3/4 of an inch. The 8000/G is 4" and the 800 is 3.25".Thanks for the pictures Marc! It also looks like the dimension from CL of King Pin to CL of tie rod end is longer than the 800 original setup. Are my eyes playing tricks?
What did the longest one come off of. My 8199KT, 16-G, and 24-G have the 4" cl to cl. All with clinch bolts.There are more different lengths than that.
I don't know what CL means but the pieces are identical on my 18G and 8179KT. They are both 5.5" long overall.What did the longest one come off of. My 8199KT, 16-G, and 24-G have the 4" cl to cl. All with clinch bolts.
CenterLine to CenterLine. Center of axle weldment hole to center of tie rod hole in this case.I don't know what CL means but the pieces are identical on my 18G and 8179KT. They are both 5.5" long overall.
