We got the steering shafts made and the steering can now be called as ready.
The space above the bevel box was so tight that the input joint could not be used as is. The bolt connection to the steering shaft had to be cut away and the shaft welded to the joint. Also the shaft between the bevel box and front axle was shortened a bit from the slide part to allow mounting without removing the bevel box.
