No...no recoils etc. I may have a starter or two though. Cant really think of any LGT stuff I need....I dont suppose you have a spare starter, nice to have a spare on hand.
Take some measurements on your carb etc and we will compare, save you making a trip for nothing
Here's what I could get Poncho......
The actual body of the carb is dead straight and 6 5/8" long overall.
Bolt holes in the flange to the engine are 1 11/16" center to center.
That bolt flange is about 15 -20 degrees off parallel with the main body.
Flange inlet opening to engine is oval, 1" x 1 3/16".
Flange for air cleaner is 1 3/8" ID and 2" OD.
Distance between air cleaner bolts is 5 1/2".
We'll see how this compares to your 12hp carbs, thanks, Larry
And unfortunately the only spare working starter I have is on my 12hp which will replace my 16 hp if it gets in trouble. I believe I have 2 dead starters in pieces, probably scrap as magnets are loose.
I do have a spare gear trans (still in chassis) if you need one. Larry
EDIT: just had another look at your pics and they are different. On yours the body curves to the engine flange. On mine there is a 90 degree bend then a 15 to 20 degree offset.
Maybe later model, maybe different all together for the 12hp.
