Ford 2000; 3 cyl gas; 4/1 trans....I have some mature holly bushes and some privet hedge that I would like to pull up roots and all. Is it feasible to use my lift to pull these out of the ground? Trunks on the holly are 3"-5" diameter, smaller on the privet. If feasible, should I use a strap or chain? Anyone done this successfully? Any particular method of wrapping strap or chain? Thanks.
I've used a 3pt drawbar with chocker chain. I've been pulling bar berry bushes out for the last two week. they also have something for pulling fence posts that would work on small trees. Check google or youtube.
I use a chain wrapped around the base of the bush and connected to the draw bar, and then just drive forward and it rips right out of the ground. On stubborn ones it may take a few rolling jerks to get it started.
Trying to pull them by driving with the chain connected to the 3 point could potentially lift the front wheels off the ground and could cause a rollover. Lifting with the 3 point without driving forward is safer but could still lift the front wheels off the ground.
Thanks for the photo....I have plenty of chain so can rig up a pulling chain similar to the one you showed. May have to cut one holly bush out by hand since it's right over the water line coming into the house. Would like to avoid any wet surprises.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
My Tractor Forum
