The 816 liftable rear hitch is different than the 8000. The 816 has two arms, one on each side of the engine and the 8000 has a single arm. While the 816 hitch can be fitted to a 8000, it does require some messing around with the rear deck clearance. My recommendation it is use the hitch designed for the tractor unless there is some compelling reason such as availability, extra strength, etc.
