I have a quick question, on my 42 9N, I changed all the fluids when I first got it. Put 90W in the trans/sump/diff. The fluid is clean and not water contaminated, at least that I can tell. I have a 6 ft blade on back for snow removal.
Question: when I first start it up and it is very cold (say below freezing as definition for cold), the pump makes a knocking noise when I operate the lift control, and the lift will not operate. Let the tractor run about 5 minutes and warm up some and the lift starts to slowly work. Once warmed up it works fine, very fast and no hesitation. It does leak down fast so I know I have some bad seals and the pump probably needs rebuilding. But why does it not work when cold? Seems to me the seals being bad should work *better* when cold since the fluid is thicker?
Thanks for any help and understanding what I have going on, Terry.
PS - been getting a work out with all the snow we have been getting here. Received 10 inches on Mon Dec 19, and then 17 inches more on Dec 22-23. So much snow I can no longer push the snow off the side, it moves my tractor sideways. Need some warmer temps and melt off some of this snow!
