I don’t have an inventory system and spent more time than usual trying to determine if I have a part or need to order one. I have a couple of shelves I put stuff on and squeeze as much as possible in each cubbyhole. This is another reason I don’t like pulling parts from a machine that is sitting. Easier to look at the machine and know in seconds to minutes if it has the part or not. I am at a stage where I’m about done and over it already and wanting to start thinning the herd. Problem is I want to do a couple restores and might need those parts tractors etc.
But when tearing down an engine I’ll use cardboard that I have drawn shapes on, to orient engine front/rear/left/right and make holes in the cardboard that I slide bolts into so the bolt goes back into the same exact hole it was originally removed from.
This helps prevent putting too short or too long of a bolt in the wrong hole as well as limiting the amount of damaged threads. In the event one bolt has damaged threads it won’t damage other threads in a block etc. I do clean threads with tap and dies for the most part.
