After removing the fender pan and dash assy, the bolts should have been exposed to remove the whole steering column. You will have to remove the bolts that hold the bearing to the side of the battery tower and remove the bearing to facilitate removing and installing the column. I don't see how you can do it any other way. By the way, the only way to remove the driveshaft is to unbolt the engine from the pan to get the clearance to remove the shaft. It has centering bushings on each end that are a light press fit. Undoing the bolts won't allow you to remove the shaft.The distance between the engine and trans must be opened up about 3/4" to expose the bushing and get the shaft out. The only way to accoplish that is to unbolt the engine and move it. I hope this helps.:goodl:
