21 - 40 of 1794 Posts
Well,the yellow painted one has a hole at start and pretty deep crater at end,[paint does help though.The second picture look like its got a good enough weld to serve the pupose of what ever it is.
Run ahead of the pack
Here's a other one.
Lincoln Weld Pak 100HD, 0.35 flux core innershield 71T on .075 regular steel.
The flux core one there,looks like you was just making abig tack weld than makeing another big tack weld right above and so on,
And this one
This is a tough one .... Alum arc rod... Its some of the hardest welding to do....
Look like it still have flux on it. :)
There was plenty of heat, I was just using the wand like I would a stick welder to get that effect....
It's only going to be used as a front bumper, weight bracket, and plow frame. It'll hold!
Try your cap like that, looks cool when painted.
Rob
I weld 130/170 ton mining trucks at Caterpillar in Decatur, Illinois.
Every one has a different skill level, keep practicing, it will come to you.
I wouldn't want to try my cap like that,I like weave beads[or what ever combination thingy you got going on there,] if thats what your saying,but I like mine a tad slicker than that. No offense intended,just the facts.
TE Writer!
Discussion Starter #34
My welder (3yrs. old) had it since new, Miller PipePro, Pipepro Dx single feeder. 0.35 wire, 75%argon 25% Co2 and 90% argon 10% Co2, Bernard gun w/ Centerfire tips.
Root pass (GMAW) 1-GR on 10" sch 80, Level III x-ray (outside)
Root pass (inside) i couldnt get any closer, too much flash! I tried thou.
Cap (SAW) i left alittle flux on, for those of you that have never seen it before.
(Orbital) TIG. a sample piece i made.
Well,those are good looking welds,you must work in a pipe fab shop?
Everything was rolled ,right?[know the sub arc was],..
What is a level III x-ray?,heard of x-rays,heard of level III x-rayers,,but never a level three x-ray,,,must be a company thing??
How are you at welding pipe in postion?
TE Writer!
Discussion Starter #37 (Edited)
Thanks rrg. I do work in a piping fab plant. Everything was rolled in the pics, for the exception of the (orbital) TIG, We conform to B31.1-B31.3, Level III X-ray is a level III read, film must be read by a level III tech. It's not a company thing, we are required by the code depending on what it's used for, high pressure steam line to jet fuel, cold water return or supply. I have to weld in position 50% of the time. (weld-o-lets, vess-o-lets, TEEs, pipe too big for my positioner) typical...SMAW 6010/7018, and TIG on socket welds, carbon and stls. I'm not bragging, or pulling this out of my ***, but i can't remember the last time i had a repair, it's been a long time. if thats what you wanted to know about how i am at welding in position.
Mike
TE Writer!
Discussion Starter #38
Rob
I'm the type of person to over do it, I would bevel the egdes, making a wide V groove, and run 2 or 3 stringers side by side, grinding half into the first and sec passes with a 1/8" grinding wheel, or run one pass uphill. I like to smooth out the welds, but not making it flush to the pc. when it comes to painting, unles it was TIG welded. I know i know to each his own.
I don't think your required by code for a level III to read the film[know that as a matter of fact],more than likly the AI requires that a level III read the film,course,according to code,the AI is boss,but ,,,If you had another AI,he might let A level II do it,,its his disscretion,,, in any case,its not called level III x-ray probably anywheres else but where you work.....
but,,you sure win the contest so far today!!:trink40:
ADMINISTRATOR
Not a great photo. I have a Miller Synchrowave 250. Self taught...........no certs.
