1 - 20 of 76 Posts
We've discussed it in other threads; now I made good on my threat and increased the psi on the implement relief valve by adding shims. Not a difficult task at all - took about two hours. Here is what I did.
But first *** Disclaimer *** This is something I have done to my machine at my own will. It is above the design spec although informally, a tuff-torq engineer said it would be fine, and others have also done the upgrade. I accept the risk that something may fail on my machine. Do this at your own risk. ****
Pic #1 is the patient.
#2 are the shims I got from McMaster
#3 is the pre-shim psi at a front quick-connect
#4 take off the fender and be greeted by lots of dirt.
...To be continued
Discussion Starter #2
#5 remove the tank and some more brackets to reveal a crud-covered tranny
#6 a quick cleanup and you can see the center valve block. The relief valve is the hex-head between the two check valves. Be very careful to clean the crud from around the valve when removing.
#7 This is the relief valve plunger assembly. It unscrews rather easily
#8 separate the components, and you get the hex nut, o-ring, washer, shim. The K92 spec sheet shows two shims by default; I only had one. The shim to insert is above the center washer.
...to be continued
and the results:
#9 psi increased to 1150 with one .5mm shim
#10 psi increased to 1300 with two .5mm shims.
#11 is the exploded diagram of the valve block. K through R is where the action is.
I put it all back together and didn't have any bolts left over. :)
Initial test:
It was dark so I could not go crazy with testing. But I can lift the front of the tractor without issue (couldn't do that before), steering is noticeably easier even with weight in the bucket, and the few scoops I took in the mulch pile were obviously more powerful. Watch this space for more updates.
The gold one is just a washer; the shim is to the right. Yes, that is where I added them. The valve is located just below seat. If not for the free-wheeling lever you could make this change just by lifting the seat.
well done! good pics. having read your previous posts (I notice you work that thing hard), I predict you'll be very happy with the improvement.
WOW!!!! Great story and presentation Randy. Would scare the crap out of me if I had mine in that many pieces.
And what do you do in your spare time? :ROF
9K+ Poster
Randy,
Great post! :thThumbsU Please let us know how much more responsive the hydraulics are. :)
Discussion Starter #12
Thank you fellas. If I had known how easy it was I would have done some time ago.
Some more playing around yesterday. Basically it has become much more powerful. It either lifts what I ask it to, or it lifts the back end trying. One day I will get enough bags of weight so I can measure capacity. When I first got it, I measured 540 pounds to full height, although it took a looong time to get there. Which brings up another operational nicety. It operates more like I would expect hydraulics to operate; heavy loads lift at a normal speed now.
This has also got me wondering about the physics behind this charge pump design. To get to max pressure, whether the default 1000psi or the upgraded 1300psi I had to hold the joystick for a few seconds while it built the pressure. Contrast that to the PTO pump for the logsplitter - when that ram hits an immovable object the relief valve kicks in immediately. So this gives me a margin of error - if I attempt to lift a too-heavy load, it won't reach 1300psi for a few seconds, allowing me to rejudge to attempt while easing the ultimate load on the hydraulics. That's my theory anyway.... :)
I don't imagine I will be maxing this out all that much but it is nice to be able to lift up mulch from the bottom of the pile.
Discussion Starter #14
Yes, what you see in the pics is necessary. It is very simple though. Took two hours the first time I did it. I could do it now in half that. No special tools needed either.
Randy, did this mod increase the speed of the hyd as well? If not, is there anything that can be done to make the bucket respond a little quicker?
I too made the modification to me 2006 XL almost 2 years ago with not one problem. Regarding an increase in speed of the loader, check out this post I made last year.
After reading that post from Steadlite about a year ago, I did some dig'n into this shimming deal to see what I was getting into. I talked to engineers at both Simplicity and TuffTorq. Both knew of the modification and both said within reason, I shouldn't have a problem. TuffTorq told me not to exceed 1250psi at the pump/transmission....He wanted to make sure I didn't take pressure readings only at the quickconnect just in case there was some kind of restriction in the system.... So I did the modification. Here are the results:
Pressure at Pump/Transmission before modification @ Wide Open Throttle =975 psi.
Pressure @ Quick Connects before modificatioin with Engine @ WOT = 975 psi.
Time to Full Lift with Bucket Empty = 5.3 Seconds.
Bucket Height with 500 lb load @ 5 seconds lift time = 35".
Bucket Height with 700 lb load @ 5 seconds lift time = 15".
Modified to 1200psi min 1250psi max @ WOT.
Pressure at Pump/Transmission after modification @ WOT = 1200 psi.
Modified Pressure @ Quick Connects with Engine @ WOT = 1200 psi.
Time to Full Lift with Bucket Empty = 4.6 Seconds.
Bucket Height with 500 lb load @ 5 seconds lift time = 65".
Bucket Height with 700 lb load @ 5 seconds lift time = 42".
As you can see, the modification really works. I've put over 100 hours on the tractor/loader since the modification with zero problems and right before I posted this message, I plugged in the pressure guage just to see how things are holding up. Pump pressure = 1200+ psi. Modification was pretty easy, about 1.5 hours total. Hardest part was taking off the rear fender and gas tank.
Another quick note: Both Simplicity and TuffTorq told me the transmission takes the most abuse when you're lifting a load the the loader stops lifting. That's when the heat really builds up. If the loader's having a hard time picking up a load, I back off right away and repick a smaller load
Bottom line is I'd say it does speed up the loader, especially when loaded.
Great info. thanks!:trink40:
Randy -
I would like to try this mod on my Massey 2927. I read your posts and see that the first step is to check the pressure. Could you detail what I would need to check the pressure? I have seen plenty of gauges with 1/4 inch male threaded connectors. Does your gauge have a tube and quick connector?
Thanks!
Discussion Starter #19
I got the quick-connect kit from www.aux-hyd.com, from a recommendation on the original thread that I got the info from. I think it's ~38 bucks. It has the quick-connect which I use on the front. I may mount it permanently on the dash if I figure out where to connect directly on the tranny.
A dash-mounted gauge would be a nice mod. I'd like to see pictures when you get it complete.
I would imagine it wouldn't be that hard, but the hydraulic chart in the manual is pretty confusing.
I was hoping to install a hydraulic quick-connect on the rear for a log splitter. I don't understand how there are 2 sets in the front and only the mower/3 pt lift in the rear. It has to be possible to add another port in the rear...
1 - 20 of 76 Posts
