Hi,
I've inherited my Opa's Ingersoll(Case) 448. It's an 88 with the Onan 18hp of course. It's been sitting for roughly 10 years.
What I've done so far having read many many posts :
Changed all fluids
Removed cylinder heads and cleaned off all carbon deposits including valves
Replaced Battery
Replaced plugs
Cleaned Carb
removed shrouds and cleaned out all dirt and debris(mouse nests)
New intake and head gaskets
After doing all the above I started her up. vvvrrooom. I was pleasantly surprised, considering it hadn't been started for 10 years or more.
However, my delight was short lived as I could hear an obvious misfire.
I felt each cylinder head and the left was room temp and the right(obviously) was hot. So I checked for spark in the left and there was none. From what I've read I should do some electrical diagnostics on the coil and the points system. I'm not very electrically savvy so I was wondering if maybe there was a quick answer someone may know of, given the symptom(one having spark, the other not), that may help me bypass doing all the electrical diagnostics.
Changed all fluids
Replaced Battery
Replaced plugs
Cleaned Carb
