Okay guys I wanted to share this repair that I did on an early F series carb air filter hinge. When I received the mower it had the early air filter cover with the hole to accommodate the hitch pin
clip which was a factory change to help keep the filter cover from falling off. However on the hinge side the slot for the filter to fit into had been broken off the carb air filter box so a screw was installed to hold the hinge side on. That would work okay until you wanted to change or clean the filter so this is what I came up with. The later F series used a wire bail clip to hold the filter cover on after snapping it closed. I had a number of these and decided I would try to adapt the wire clip to hold the hinge side in place. After some careful measuring, wire bending, and a couple of small holes drilled for the wire clip I slipped the filter cover in place, swung it closed, and installed the factory hitch pin. Worked like a charm. Now I can swing the cover open and remove the filter for cleaning or slide the cover completely off if needed. Hope the pictures do the modification justice. Bill
