Thanks to helpful MTF members (especially Lawnboy77 and Bald-Guy), my D-448 engine is now running and "fully mission capable." It needs only a little carburetor tuning and an rpm adjustment. I hope to restore the deck over the winter and would appreciate advice from those who know this work better than I do.
My self-propelled 1972 vintage 8229B has a cast magnesium deck. Questions:
1. There are several small holes. Do I take it to a welding shop for repairs?
2. Underside has some pitting. Should anything be done other than cleaning and painting? Does the pitting need other repair?
3. Should I try to remove all the remaining old paint before repainting? What is "powder-coating", and is it necessary?
4. Any ideas on removing rust from blade and blade stiffener? Have tried Naval Jelly, muriatic acid, wire brush, steel wool, etc. and have had little success.
This is a "working mower", sees lot of use and will not likely match the fine restorations some of you have done. The restorative work I am doing now, however, is long overdue. I will try to make and post "before" and "after" pictures. Thanks.
Jim
Jim
