1 - 2 of 2 Posts
LAWN MOWER, MTD, 24 HP BRIGGS AND STRATTON ENGINE. Mower has stopped charging the battery. The volt meter is centered on the line between charge and discharge, until I turn the mower on, which is an electric clutch, and then it goes to negative. Where can I find the charging unit on this mower, or what do I need to replace. Thanks Larry
.If you go to the Briggs and Stratton website.You`ll be able to find an owners manual, and a complete Parts list for your Engine,after you enter the Model and Type numbers into their search engine..
1 - 2 of 2 Posts
